Sammy Hing, what do you think ?  Can you buy for us and ask somebody to install?
RK New Hand
tkwan 發表於 21-7-2010 23:43
If you can found it on Taobao, then I can get it for you easily. But for installation, you will need to look for a c-fu by yourself or try try DIY.
But is the sound proof on RK really that bad? When I test drove it, I found that was much much better than RG already.
DIY, it isn't difficult.
You can change speaker together.
15# sammykwan
No ar... only one USB drive for play music .. and I am sure the noise is from the ground
15# sammykwan
yunggaryhotmai 發表於 22-7-2010 00:13
What tyre and wheel are you running?
To All C hing,
I did DIY sound isolation for my RG's front and rear doors and rear floor, the material is 平静. I can hear someone speak clearly from the 3rd row. The noise is much lower than before, ...
Perry2007 發表於 21-7-2010 23:22
"I can hear someone speak clearly from the 3rd row"
me too......but i didn't installed any sound proof material
x4dragstar400 發表於 22-7-2010 00:46
That very much depends on who is "someone"
HAHA Someone ... so scare lor ..
My tyre is come from orginal .. I forget tim  :(
Hi there, I told my driver about the road noise and he then took the car to the gas station to release some of the tire pressure. I noticed some difference afterwards. Maybe you can give it a try and do let us know if it helps.
The stock Dunlop tyre is really noisy...
What noise are you talking about: Road, outside, wind or suspension? I picked up mine a month ago and I also think the car is a bit noisy, though I think its not really bad. I feel the noisy mostly from underneath. Thus Road and suspension. I have done a lot of sound proofing a lot with my previous cars, and I think I know how to tackle this problem. You must use few types of materials to filter down the noises. You could DIY if you have sufficient tools. Let me know if you are interested to know more!
I think it is quite related to the tyres
the SPADA has Yokohama dB and it is quite good! But the tyres can only do so much, because the suspension will convert the vibration to noise. And the chassis is hollow, which helps amplify the noise....
Dynomat sound proofing system is the best, but it is bloody expensive....
