冷氣問題
部車後面開左冷氣之後,右邊車身最後面哥塊玻璃出面有水氣積係度,咁係咪後面出風位有問題?搞到哥邊溫差唔同而出現咁慨情況?
stanleykun 發表於 1-8-2010 00:16
too cool la.....the temp diff will condense water drops.
> try 23-25 deg at A/C if out side temp is ~ 30 deg
our A/C is NOT a numeric setting , it compares the temp of out side.
i.e. cold air come out = if u select 25 c (outside is 30 c,) lower temp than outside
warm air  come out = if u select 25 c (outside is 20c ) ,higher temp than outside
我已經係選25度,外溫睇過係30,但係正係哥塊玻璃係咁,其他又唔怕慨?會唔會右後邊漏風吹住玻璃?但係風管冇理由去到咁後架?
我個架都係咁,因為下面有個制冷器,無問題的。
車尾哥邊都有制冷咁勁@@,怪得咁得意正係哥邊有發熱線...
stanleykun 發表於 1-8-2010 21:01
I have the same case too, but that is not hot wire, It's 天線.
可能係水貨換左玻璃先會出現呢個問題,有冇買左行貨車慨大老會咁??
8# stanleykun
有呀...我部行車都係咁~
問過sales佢都話係果個位有部制冷機引致有溫差出現冷凝水~
我都係咁...
Mine, too!
RK New Hand
Mine as well
係條泠風糟無接, 漏風, 溫差大, 所以有倒汗水!
我上次泊好車之後 屎弗癢 走去望車頂 連車頂 都有
I removed the plastic trim (seatbelt cover) and taped around two piping, now is better!!
