2010 Stepwgn
請問各位ching以下問題:-
  • hk 2010 stepwgn 喺咪應該屬於 RK1 車系 (RK5-FF/RK6-4WD 係spada ; RK2-4WD)
  • 咩解究日本原廠嘅呔鈴係前後size唔一樣
      • e.g. 前:206/60R16  後:205/55R17
      • 係咪操控上有分別,抑或純粹外觀
請問各位ching以下問題:-
  • 係咪操控上有分別,抑或純粹 ...
    wongpatr 發表於 27-1-2010 02:20
  • You misunderstood the data sheet la.......
    If you look at the bottom of the data sheet, it mentioned that "〈 〉内はメーカーオプションの「16インチアルミホイール」装着車。" So, it is either 15" or 16" wheels for both front and rear wheels, not mixed 15" and 16" on the same car.
    ref: http://www.honda.co.jp/STEPWGN/webcatalog/spec/
