請問RK1尾燈點拆 ?
I followed the manual and removed the two screws.  But cannot take out the lamp cover.  It seems there is 有扣扣住 on the other side.  Any C Hing can tell me the trick?  Thanks.
哈哈又偷電.....
鬆咗2粒鑼絲,跟住manual話個方向,向外(右燈向右,左燈向左)推。
上邊粒碼仔會緊d,下邊粒碼仔會鬆d。建議用手按住燈座下面,跟住用拳頭係上鑼絲位用力向外dup.....
GOOD LUCK
platform 發表於 3-3-2011 00:28
ching...見議你柝尾門板換..
ching...見議你柝尾門板換..
chowchow115 發表於 3-3-2011 09:05
ching, 佢好似唔係拆牌燈喎......
fw18 發表於 3-3-2011 09:06
sorry..係我未訓醒...看多左個字...
Thanks fw18.  I was not sure about the direction to remove the lamp and worry to use any force may damage the lamp or side panel.  I will try again using your method.
platform 發表於 4-3-2011 01:15
ching, 就住度力喎......
Hi fw18 Ching,
I try your method today.  下邊粒碼仔ok but 上邊粒碼仔 is very tight.  I try to push but the lamp cannot come out.   I don't think remove the side panel can help.
There must be a way to take it out but how??
本帖最後由 fw18 於 14-3-2011 13:14 編輯
第一次係噤。我都攪咗幾次先得。之前個方法係最易了。因為下邊粒碼仔一推就出,所以要用手按住燈座下面,推出上邊粒碼仔先。如果唔係好難拆個燈座。記住,先拆上,后拆下。唔係好易拉爆.....
ching, 你多數係邊區出末呀?
不如搵 ching 拍D示範片擺上黎公朱同好,我今朝拆燈座又遇到同样問題,
又怕 dup 爆个燈座
小名陳咖哩, 又名 Chan Gary
茶實糸咪拆兩粒鑼絲,跟住用少少力向外一拉就OK
小名陳咖哩, 又名 Chan Gary
其實拆咗螺絲之後,喺趟門條糟果個窿向外拉,就好容易拆出黎
George
Aliens 發表於 19-11-2011 14:35
later try again sin, thanks
小名陳咖哩, 又名 Chan Gary
