求救!加了throttle controller 之後有問題
用咗三個月,近呢兩三日出現咗engine燈,試過凍車disconnect 電池負極reset ,行咗大15分鐘又出現,點算?
二零零六RG1。Hello everybody I'm Stanley
Sboy504stanley 發表於 2012-11-25 12:52
Stanley, 會唔會真係Sensor到期 (O2 sensor ... etc). 06車都有可能. 去車房 check check. V-checker 好似check
cliffchow 發表於 25-11-2012 12:59
聽聞個O2 sensor 好貴喎!
Sboy504stanley 發表於 25-11-2012 12:52
Did u change mode on the throttle controller when driving?
If not, u may try to discount the controller to see if the same problem still exist
sammykwan 發表於 25-11-2012 13:05
有時會行車途中轉,乜會有影響咩?
有時會行車途中轉,乜會有影響咩?
Sboy504stanley 發表於 25-11-2012 13:13
If so, please tell me if the engine light comes up right at the time you are changing mode......
o2 sensor 唔會太貴呀, 一千幾百.....
一般都係車房搵笨收天價
why not disconnect the throttle controller to try, if discconnected and engine light not on, it means throttle controller affected problem, but i think it is less of chance.
go to use obdII checker to read any error message .
go to use obdII checker to ...
nana4hk 發表於 25-11-2012 13:49
I try to disconnect the controller tonight
