Air bag light RG1
請問大家有冇換過Air bag 燈?我dash board 個air bag 蹬燒左而家開匙吾著,我找車房睇個air bag 正常所以應該係燈燒左,佢叫我吾洗換
本帖最後由 sammykwan 於 18-3-2013 09:27 編輯
点睇到係正常?插腦?
Rival100 發表於 17-3-2013 13:33
Why dun ask the CF to switch the blub at the same time ....
As Air bag is very important to safe your life, it's better to make it all clear
点睇到係正常?插腦?
sammykwan 發表於 18-3-2013 08:35
Yes, the computer shows the airbag work but the light does not work. He never did it before because he is not a Honda tech guy. I wonder if u guy has any experience to replace those bulb
Rival100 發表於 18-3-2013 09:42
seems RG's light is on one piece big panel......if c-fu said it is fine, better leave it.....
do you have EML327 OBDII ? I use this OBDII to check if there is any error code. you can connect it to your BT Android.  you can buy it from taobo "  迷你 MINI ELM327 Bluetooth OBDII obd2 蓝牙elm327 汽车检测仪 "
