本帖最後由 sammykwan 於 11-12-2014 03:04 編輯
max should be 55... 48 still ok in winter
nevillee 發表於 11-12-2014 00:33
after running, the tire pressure can be increase by 10 PSI...in fact, not all the tire has max 55psi....some are only 50psi
And most important is not higher the better, so from my understanding, there is no point to make it so high.
本帖最後由 sherman 於 11-12-2014 09:55 編輯
And most important is not higher the better, so from my understanding, th ...
sammykwan 發表於 11-12-2014 03:03
自從跌咗啲錢,執番個橙之後, 可以即時睇到軚氣數句
通常我渣車去油站打48後, 跟住啲數字都係徘徊42~49之間, 唔會超過50
這應該係同我駕駛習慣和用車模式有關, 我係唔會經常去chur條軚旣
RK5 原廠建議呔壓係:前轆32psi,後轆35psi;而原配嘅車轆標示max51psi。
我都有裝TPMS,感覺溫度對呔壓影響幾大,尤其是前轆。我自己吾敢打太高,一般打前轆35psi,後轆38psi左右。因我冇換/升級鮑魚,怕呔壓太高傷呔且影響制動
創造價值!
generally 3-5psi la, so that i say in winter law...
三哥 係時候準備歸隱
