呢招 over 100 未必 work 掛
imstan 發表於 8-3-2011 09:58
Yes, It works. Maintance your speed and slow down very slowly. That is what I learn from the insurance class in Toronto. NEVER HIT THE BRAKE RIGHT AWAY. Your car will spin because the wheels with unbalance speed.
It works......It happened to me once at 140........
Yes, It works. Maintance your speed and slow down very slowly. That is what I learn from the insurance class in Toronto. NEVER HIT THE BRAKE RIGHT AWAY. Your car will spin because the wheels with unb ...
alliven 發表於 8-3-2011 10:03
It's seems Canada's education system is better than HK...wakakakakakaka
SAMMY兄..可唔可以話比我知SF的單 NUMBER比我..等我打個電話問下佢...送比我未? THANKS
chowchow115 發表於 8-3-2011 09:59
put at the post law....http://www.stepwgnhk.com/viewthr ... amp;page=1#pid92635
waybill# 852640192272
sammykwan 發表於 8-3-2011 10:05
Flat tyre at 140
Flat tyre at 140
hkmangor 發表於 8-3-2011 10:09
hold the steering wheel steady, light brake with good control, and get onto the shoulder slowly......very easy to handle.......
理論上係,實際上有無咁振定又係另一回事
理論上係,實際上有無咁振定又係另一回事
imstan 發表於 8-3-2011 10:11
actually, in the car if you don't press hard brake, the car won't lost control....and you can feel the changing of the handling slowly........
but for sure, if you give it a hard brake and the car start spinning.....then only expert can get it back on track.....
"2011-03-08 08:43:48 正在派件 " get some one stay at home now ar!!
sammykwan 發表於 8-3-2011 10:06
Wakakaka, 我唔係受 HK 教育㗎
but for sure, if you give it a hard brake and the car  ...
sammykwan 發表於 8-3-2011 10:13
But another critical condition is, no other car following or nearby you !! You may well control your car to hard shoulder but not the followers !!
imstan 發表於 8-3-2011 10:21
wakakakaka.....I have only took 1 driving class in HK, the instructor mainly taught me how to deal with the taxi drivers and mini-van drivers on the road.....
b2bxhk1 發表於 8-3-2011 10:23
even there are followers.....you have to slow down and stop...no choice with a flat tyre la....
Seems right!!
揸咁耐試過一次救車,果次行啲類似 rally 賽道彎位甩尾,落小 brake + 扭呔救得番無炒,果時行接近100
