BRAKE LAMP 行車時突然時亮時滅
有無 C HING 部車出現過同樣情況,最後是怎樣解決的, BRAKE LAMP 行車時突然時亮時滅,BRAKE油查過正常。
Brake 尾燈有隻消左
我是 "高達仔" ....
將左右兩盞燈掉換試下係唔係燈既問題
本帖最後由 sammykwan 於 17-12-2013 12:07 編輯
turbojet 發表於 17-12-2013 11:05
If the brake system indicator comes on while driving, the brake fluid level is probably low. Press lightly on thebrake pedal to see if it feels normal. If it does, check the brake fluid level the next time you stop at a service station. The fluid level should be between the MIN and MAXmarks on the side of the reservoir. If the level is at or below the MIN mark, your brake system needs attention. Have the brake system inspected for leaks or worn brake pads.
If the fluid level is low, take your vehicle to a dealer, and have the brake system inspected for leaks or worn brake pads.
However, if the brake pedal does not feel normal, you should take immediate action. A problem in one part of the system’s dual circuit design will still give you braking at two wheels. You will feel the brake pedal go down much farther before the vehicle begins to slow down, and you will have to press harder on the pedal.
Slow down by shifting to a lower gear, and pull to the side of the road when it is safe. Because of the long distance needed to stop, it is hazardous to drive the vehicle. You
should have it towed and repaired as soon as possible.
咁大篇野,你打㗎?
2015 鮑魚小組要改名:鮑魚軍團
take immediate action 唔似Sammy's style..
"take your vehicle to a dealer" <==呢個都唔似SAMMY風格
咁即係出貓
2015 鮑魚小組要改名:鮑魚軍團
咁即係出貓
victor 發表於 17-12-2013 17:31
at least I spend time to copy it..
sammykwan 發表於 17-12-2013 17:51
Charles
如果錶板brake燈著,一係brake fluid不足,一係brake pad唔夠要換。
如果brake fluid夠就多數 brake pad太薄要換
8609 發表於 17-12-2013 20:12
that match with my post..
唔夠brake fluid唔會閃下閃下,通常唔夠皮初期先會咁。
如果用緊原裝皮,唔夠皮個鉄片係落brake 時會磨brake disc有磨鉄尖聲。 hand brake drum pad除外。
非常多謝各位 C HING 之意見,因早前天天下兩,沒有時間拆下brake pads來檢查,我都是有用肉眼望過下塊皮,發現還有6MM左右,昨天天氣非常好所以去換油時順便加 brake Fluid ,當時發現 fluid level should be between the MIN and MAX marks,之後到今天再沒有出現過brake lamp 會閃下閃下。星期六有時間拆下brake pads來檢查先,我想都係時候需要更換塊brake pads。之前我怕brake system 可能有D 甚麼大問題,沒有想過brake fluid level 低小小都會出現以上問題。
