點煙器fuse
請問各位師兄,點煙器個粒fuse係邊個位置?
Fuse numbering of RG, early RK and late RK are different.
Check the fuse of ACC from one of the posts in 維修保養->精華區 below
http://www.stepwgnhk.com/forumdisplay.php?fid=56
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
Overlook that u are not 正式會員
Btw, is yours RG/ early or late RK?
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
本帖最後由 Liyunfat 於 26-3-2015 10:37 編輯
Yep, I couldn't open that link. Thanks for your quick reply.
Mine is RG1
Btw, I was installed a car cam recorder and hook up the power with the radio fuse, but then it draw out my battery after a few days, I'm looking for a fuse which can stop supply power when I turn my key to off position and can lock up the car.
Any suggestion Kingcow?  thanks
Mine is RG1
Liyunfat 發表於 2015-3-26 10:31
http://www.honda.co.jp/ownersmanual/HondaMotor/auto/
呢係public searchable, 裡內有stewpgn user manual. 有講.
Mine is RG1
Btw, I was installed a car cam recorder and hook up the power with the radio fuse, but then it draw out my battery after a fe ...
Liyunfat 發表於 26-3-2015 10:31
Try fuse no. 32
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
Thanks, it seem working fine with fuse 32.
What does ACC mean btw?
ACC -> accessories
A car ignition switch normally has 4 positions viz Off, Acc, On/Ign and Start. When the key is in the Acc position, 12volt is supplied to cig lighter and car radio, etc so they can be used without the engine running.
一般的汽车钥匙有4个档位,一个是“OFF”,一个是“ACC”,另外一个是“ON”,还有一个就是发动档,但是大部分大众车型(像红旗,奥迪等)都是3个档位,也就是没有“ACC”档
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
ACC -> accessories
A car ignition switch normally has 4 positions viz Off, Acc, On/Ign and Start. When the key is in the Acc position, 12volt is supplied to cig lighter and car radio, etc so they can  ...
Kingcow 發表於 27-3-2015 17:55
Understood. Thanks for that useful information.
One more question, do you where is the turn signal relay located? I tried to install a LED turn signal bulb and then the blinking rate went crazy..
Several old posts mentioned this issue, but you have to join our club to see it.
http://www.stepwgnhk.com/viewthr ... E9%96%83&page=2
http://www.stepwgnhk.com/viewthr ... =%E5%BF%AB%E9%96%83
曾經有member 打住死火燈聽聲搵, 係FUSE BOX 上面搵到個relay, 但市面搵唔到6脚relay取代
Instead of changing the relay, 可以要並聯一個20W水泥電阻在LED燈上就可以解決快閃問題
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
