- Hong Kong
- 6352 小時
16#
發表於 27-11-2011 01:20
may be the parking entry there is a card sensor (e.g. octopus reader) or some radio device affected your keyless system which blocking your keyless remote signal...and makes the car thought the key is ...
sammykwan 發表於 26-11-2011 21:58  Sammy, once you had start the engine, RK1 keyless will not auto turn off engine even no key signal. If you keep turn on the engine you can go anywhere without key, once you turn off engine you can't turn on again |
